broken exshaust bolt iin block
Old May 11, 2008 | 12:35 PM
JDAWG901's Avatar
JDAWG901
Default broken exshaust bolt iin block
i accidently over tourqed 1 of my exshaust manifold bolts and broke off the .1 of them on top.any simple suggestions on removing it.
Old May 11, 2008 | 01:52 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: broken exshaust bolt iin block
If you pull the manifold you should just be able to use your hand and loosen it. There should be enough sticking out of the head. Try to use a flathead screwdriver and get it to turn out. Once you brake a bolt. It usually sits in there loose. The hea od the bolt is what keeps it tigh tin there. If all fails, drill and tap.
Old May 11, 2008 | 10:14 PM
djseth's Avatar
djseth
Get a set of easy outs. You drill a hole in the remaining bolt, tap the easy out into place, and turn. The easy outs are a very hard steel with a reverse threading. When you turn them CCW, they thread themselves into the hole until the friction overcomes the bolt and it torques them out. The are not to expensive. Don't hit them too hard as they are brittle, and will break. Also, you may break one or two just in the line of duty.
Old May 12, 2008 | 01:06 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Yes,I had the same issure with my exhaust manifold bolts, the bottom 4 were broken. I thought it was going to take me all day to remove them. It only took me about 20 min to remove them. I used a pair of vice grips that worked like a charm. the manifold was completly removed when I removed the broken bolts.
Old May 12, 2008 | 01:20 AM
Ghost Neon 2's Avatar
Ghost Neon 2
May be able to se vice grips with the manifold out of the way.
