Cruise Control Question
Old May 14, 2008 | 01:55 PM
jonniewalker1999's Avatar
jonniewalker1999
Default Cruise Control Question
98 SOHC 230k miles
My cruise control seems to be about dead. Some of the time I can set it and things are good. Most of the time I set it and after about 30 seconds it drops off like I hit the brakes. If I forget to turn Cruise off at some point when I dont want it like coasting up to a light it trys to kick back on.
Any ideas?
Old May 14, 2008 | 02:32 PM
das2123's Avatar
das2123
Default RE: Cruise Control Question
Have you checked the fuse? Relay? Vacuum lines?
Old May 15, 2008 | 03:06 PM
jonniewalker1999
Where are the Vacuum lines located? It is not the Fuse or Relay; they check good and it would not be an intermittent problem those would make it a broke problem.
