Oil Pump Question
I know I've just about beat this subject to death but here it goes...
My wife blew my motor last night for sure no ifs ands or buts about it, well heres the deal I actually remembered to put oil in and it had oil, My question is could the smoking from the rings been caused by a badoil pump? The oil light has been coming on off and on for a while even though the oil has been filled up always.
I want to rebuild the motor but I need to know if the oil pump is to blame so I know if I need to replace. I think it may be a oil pump after seeing my sisters grand am have a rod knock and blow smoke out of the valve cover just like my Neon does but not as bad. Could bad oil pumps cause the rings to go bad before the rods?
I opened the hood on my sisters Grand Am and everthing is very chillingly simular to every problem my Neon has from lack of low end power to the smoke out of the valve cover. I never remember smoke coming out of anywhere on either motor. Could both of our oil pumps **** the bed and caused bad rings?
I also noticed very finealuminum shavings in the Neons valvetrain especially under the rocker arm shaft bores but none of them seemed big enough to cause a blockage.
Thanks
Thanks
