pulled it
Old May 16, 2008 | 12:07 AM
fsu182's Avatar
fsu182
Default pulled it
i lifted my pistonless, headless, panless block off the ground and carried it 3 ft. to some bricks. then i carried the transaxle 100ft to my backyard. the engine is out. finally. lifted the car up over it.
i just pulled my first motor.
if my clutch has LuK imprinted on it, im gonna go ahead and guess its been replaced. right?
also i noticed my window sticker has transmission listed as: Perf. 5 speed manual.
did they all say that?
Old May 16, 2008 | 12:11 AM
12 volt's Avatar
12 volt
Default RE: pulled it
do you have a pic?
just make sure you keep it out of the rain and dirt
Old May 16, 2008 | 12:12 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Congrats. I am driving the first engine I have assembled from the block on out. The crank was already there, but the rest was me. Feels neat.
Old May 16, 2008 | 12:45 AM
95to96transplantneon's Avatar
and as far as the tranny goes you have the performance manual version B... its the 3.95 with the .72 5th gear, that came on all DOHC cars besides the R/T and acr between 1996 - 1999
Old May 16, 2008 | 01:07 AM
fsu182's Avatar
fsu182
i got an assembled head with 60xxx miles on it, and im waiting on a response for a slightly decked 2.0 block with 80k on it. if i could find a 2.4 short blcok close for around 200 bucks id get it.... cant seem to get a hold of one though
Old May 16, 2008 | 01:16 AM
fsu182's Avatar
fsu182
thanks for the trans. info
Old May 16, 2008 | 09:29 AM
spudsterier's Avatar
spudsterier
luk clutches were original equipment on the neons
Old May 16, 2008 | 09:42 AM
Ghost Neon 2
ORIGINAL: spudsterier
I think they were OEM for replacement, because I had a SACHS in mind. That is a brand I presume. LUK use to be a an upgrade over the SAHCS back in 01', and was listed in the Mopar Performance site as a MP item. Later went to production. Sweet item though.
Old May 16, 2008 | 09:43 AM
Ghost Neon 2
ORIGINAL: fsu182
Can you get a pic of this?
Old May 16, 2008 | 01:03 PM
^^^^^^ I bet you a million dollars every single last 1996 - 1999 DOHC built neon had that on the build sheet and window sticker... becuase they ALL had them.
ORIGINAL: 95to96transplantneon
