Wheel Bearing
Old May 26, 2008 | 01:08 AM
95to96transplantneon's Avatar
Default RE: Wheel Bearing
oh and save the old hub they come in handy when installing axle seals... perfect size...
Old May 27, 2008 | 08:08 AM
cpukramer's Avatar
cpukramer
Thanks everyone for the detailed instructions ... I ended up giving up on it the other night because I had some other things to get to. I will give this another try hopefully this Friday night. Looks like I should be much better prepared this time. I will let you know how it goes. Thanks again!!
Old Jun 10, 2008 | 01:52 PM
cpukramer's Avatar
cpukramer
Ok I am giving up on this ... I looked over the factory service manual and it shows all these "special" tools that are required. I am just going to have my mechanic do it ... he will do it for $200 including parts. If I return the bearing I already bought them I am really only spending $160 to have someone else do it. Sounds worth it to me!! Thanks anyways for everyone's help ... I really appreciate it.
Old Jun 10, 2008 | 08:41 PM
JackMehoffer69's Avatar
JackMehoffer69
The Pickle fork works great, I had trouble finding a suitable way to lock the rotor while taking the nut off till my brother took a crafstmen screw driver and jammed it in the break caliper and rotor and it came right off like butter, it was easy after that!.
Old Jun 10, 2008 | 08:45 PM
JackMehoffer69
Autozone Online Repair guide: http://www.autozone.com/shopping/rep...00c1528007945c
