WTF Please help
Old May 27, 2008 | 08:21 PM
duelsxt's Avatar
duelsxt
Default WTF Please help
Ok its a 99 SOHC 60K on the car. Sat for awhile. Runs at idle fine. Drive it around the block and it dies. Let it sit a min and it starts back up. then same thing ????? Pulling hair lol
Old May 27, 2008 | 09:01 PM
95to96transplantneon's Avatar
Default RE: WTF Please help
take the sparkplugs out and checkthem...
how long is a while... gas is probally bad...
just keep it simple at this point
plugs wires battery connections... stuff like that...
Old May 29, 2008 | 03:55 PM
brushedchrome's Avatar
brushedchrome
For real. Start with the simple stuff. Has your computer thrown up any codes? Also, do you know how to read the codes?
Old Jun 1, 2008 | 08:49 AM
duelsxt's Avatar
duelsxt
Ok no codes and fuel pressure is ok. When the car stalls if you check for spark there is non. Cycle the key it comes back. Changed the ignition coil and it def made a difference but still ends up stalling......
Old Jun 1, 2008 | 11:13 AM
brushedchrome
Something that involves heat and timing. Could be a bad wire going to the coil or a loose connection to the PCM. There are a few different sensors that affect the timing when the car is warm. MAP, cam, crank, engine temp sensor. Check your connections. If you have a multimeter, start checking the sensors voltage against the listed proper voltages in a manual. When you get one that isnt returning the proper voltage or isnt reaching the right resistance as in the engine temp sensor, change it out. Be sure to check the voltage going to the sensor to be sure its not a bad lead to it.
Old Jun 1, 2008 | 02:26 PM
duelsxt's Avatar
duelsxt
The wierd thing is that when i replaced the coil pack it made it run alot longer before it quits...
Old Jun 1, 2008 | 02:29 PM
brushedchrome
It was part of the problem for sure then. The only other thing would have to do with it now loosing signal due to the computer not knowing whats going on with the timing.
Old Jun 1, 2008 | 02:35 PM
duelsxt's Avatar
duelsxt
When it dies if you leave the key on and probe the signal wire goin to the coil it is dead the green wire. cycle the key and it usually fires
Old Jun 1, 2008 | 03:05 PM
brushedchrome
The orange wire is the one to check for voltage with it unplugged from the coil. You would have to cycle the engine a couple of times because if the computer detects that the engine isnt running, it shuts the ignition feed off.
