SOHC with DOHC pistons and 2ed gen magnum Head
Old Jun 17, 2008 | 06:21 PM
95to96transplantneon's Avatar
Default RE: SOHC with DOHC pistons and 2ed gen magnum Head
no it will not... it will bolt up to a dohc head but not the sohc or mag head...cheapest way to go fast is to find a 2.4 stratus block and put srt-4 internals in it and then the srt turbofold. If you know where to look you can get everything involved for like 2500 bucks.
Old Jun 17, 2008 | 10:53 PM
RiceRocketEater's Avatar
RiceRocketEater
True say thanks man
im just trying to build a fast cheep neon
the tranny swap will b easy tho so that will add to the fun factor of the car
what are your thought on the MOPAR PCM how much hp/torque dose it add and dose it move the rev/speed limitor?
Old Jun 18, 2008 | 02:31 AM
das2123's Avatar
das2123
ORIGINAL: 95to96transplantneon
I have to disagree.....cheapest HP in Nitrous!
Old Jun 18, 2008 | 09:26 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
+1
Old Jun 18, 2008 | 11:39 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Maybe its cheaper at first. But after many times of filling the bottle I am sure the the prices will be more then a turbo setup.
Old Jun 19, 2008 | 10:02 AM
JackMehoffer69's Avatar
JackMehoffer69
ORIGINAL: I_Ride_Neon
The dohc pistons wont do anything great for ya. I have them. The magnum head is a high flow head with a more agrressive cam. But good luck finding one within your budget. GOod luck finding one period. I would say you will be at about 150 with some bolt ons, dohc pistons, and magnum head. I am sure jeremy has a comment for this.
My bet is you didn't have your fuel system set up correctly, the walbro and rising rate fuel pressure regulator were conflicting with whatthe moparpcm wanted to drag to the injectors and I doubt you had a favorable air/fuel ratio probablyextremly rich.
Whatever the case I'm sick of busting my ***** for 200hp, time to build my hemi.
Old Jun 19, 2008 | 01:08 PM
RiceRocketEater
yea! im in for a hemi im thinking f*** this right now!!
not a good engine to tune(like the honda b18)
im thinking 3ed gen camaro!
and this is safe
http://www.youtube.com/watch?v=3LKJ8...eature=related
and
http://www.youtube.com/watch?v=N13KO...eature=related
Old Jun 19, 2008 | 07:08 PM
Ghost Neon 2's Avatar
Ghost Neon 2
That is thinking long-term.
Old Jun 21, 2008 | 01:27 PM
RiceRocketEater
IIght thanks people
a couppleof the things that i wanna no
1.How the hell do you get driver and passger interior pannels off... i need acces to my speakers
2a.A SRT-4 turbo fold bolts right up to the DOHC head right
2b.How much HP will that make
Old Jun 22, 2008 | 10:11 AM
das2123's Avatar
das2123
There is a torx bolt behind the door handle that needs to be taken out and then take off the window crank handle if you have manual windows. Then take the panel off.
Yes, but you need more than that to run it.
I don't know that I have seen a dyno after install, but I would assume easily over 200 HP.
