harmonic balancer, egr valve?
Old Jun 17, 2008 | 07:52 PM
rickav's Avatar
rickav
Default harmonic balancer, egr valve?
I was tring to pull off the crank shaftpulley and butthe harmonic balancer came off the wheel, If I freeze the center part with dry ice and put them back together will that work or will it set up a vibration? Second if I block the EGR valve will it effect gas milage? if so how and how much?
Old Jun 17, 2008 | 11:49 PM
spudsterier's Avatar
spudsterier
Default RE: harmonic balancer, egr valve?
there should have been a rubber piece between the 2 wheels on the pulley, but your best bet is to find another stock one or an aftermarket underdrive pulley
Old Jun 18, 2008 | 12:53 AM
JackMehoffer69's Avatar
JackMehoffer69
my EGR is blocked on my 95 sohc and I get 290 miles per tank with a few beatings mixed in, Im sure if I didnt beat it I could get 310+. For me thats an average of 29 MPG
On 10 Gallons on 310 miles per tankthats 31 miles per gallon. The Neon has a 10 Gallon tank.
Old Jun 18, 2008 | 02:39 AM
das2123's Avatar
das2123
ORIGINAL: JackMehoffer69
Wrong...95 and early 96 had 11.2 gallon tanks and the rest have 12.5 gallon tanks.
Old Jun 18, 2008 | 03:59 AM
JackMehoffer69
ORIGINAL: das2123
I was always told 10, nice to know its 12.5 in my 98thanks Das
Old Jun 18, 2008 | 08:45 AM
spudsterier
the 11.2 gallon tank is the metal one...
12.5 gallon tank is plastic
Old Jun 18, 2008 | 03:42 PM
rickav's Avatar
rickav
There is a rubber peice its still on the out side wheel, I just want to know if I put them back will it work or will I get vibrations, I am inclined to think the outside is balanced and it would be ok. Just thought somebody might know. Before I took my car apart I was getting 32 up to 35 MPG.
