really need a help, harmonic balancer
Old Jun 20, 2008 | 03:38 PM
rickav's Avatar
rickav
Default really need a help, harmonic balancer
OK any body have any ideas on getting this balancer off i have broken a 3" puller and ripped the threads out of a 4" puller. bent the bolt whenthe first puller broke. Now Im going to put attach the 3 claws from the 4" puller to an 8" gear puller ( the 8" claws wont fit in the holes ).
Old Jun 20, 2008 | 05:31 PM
spudsterier's Avatar
spudsterier
Default RE: really need a help, harmonic balancer
go to autozone and rent the proper puller....its a small 3 jaw that uses a push rod as the center push point...it will only take about 2 minuites to get the pulley off using that puller
Old Jun 20, 2008 | 09:21 PM
JackMehoffer69's Avatar
JackMehoffer69
ORIGINAL: spudsterier
I've broken the puller I used to get21/2pullys off and on the 3rd pully it broke so I had to break apart my donor motors timing belt cover and rip the new belt out of that motor with my bare hands due to those pullys being a bitch with the bigger puller.
Old Jun 20, 2008 | 10:30 PM
I_Ride_Neon's Avatar
I_Ride_Neon
My pullers usually break or strip every 3-5 times. Nothing you can do but buy another one. I get the one with a warranty so its free eevrytime.
Old Jun 20, 2008 | 10:31 PM
I_Ride_Neon
Yea 3 claw, 6 inch? Usually works perfect with the noen.
Old Jun 21, 2008 | 04:27 AM
j_son600's Avatar
j_son600
Get a snap on blue point, they make quick work of even the most stubborn pulleys.
Old Jun 21, 2008 | 05:29 AM
JackMehoffer69
On my 95 motor thats been sitting in 2 inches of water for the last 2 years the pully popped right off the way you'd expecta new oneto, VERY EASY. The pully on my old sohc that I had off not more than 8 months ago is still on the motor, I broke the timing cover and took the belt out over the pully, it sucks but when your running out of day light on a Engine swap you do anything!
Old Jun 21, 2008 | 09:59 AM
spudsterier
i have the snap-on blue point and it works flawlessly...of course, for $120 it better not give me any problems...
ive used at about 50 times since i got it, and it still works like new
Old Jun 21, 2008 | 01:29 PM
I_Ride_Neon
The one I get is about $20 a pop.
Old Jun 21, 2008 | 07:20 PM
rickav's Avatar
rickav
I attached the 4" jaws to a 8" puller with titanium bolts and alot of kroil did the trick. I made some plates to go between the EGR valve and the exhaust manifold and one between the tube and intake, let me know if any one has a problem after doing this, I think it will work well and the EGR valve will sill be there.
