just replaced head gasket, now whats wrong?
Old Jun 24, 2008 | 02:59 PM
biigby's Avatar
biigby
Default just replaced head gasket, now whats wrong?
Please help,
I just recently replaced the head gasket in my 95 neon, and now there is something else wrong with it. Im guessing it has something to do with the reassebly. When i am maintaining a constant speed or rpms it will kind of sputter or miss. although this does not happen all the time. all of a sudden it gets better and runs normal. The engine also has decreased overall power, and somethimes while accelerating it will have almost no power in each gear until it hits higher rpms. Once it hits higher rpms it will kind of catch, then there will be a lot more power. Anyone have any ideas?
Old Jun 24, 2008 | 03:14 PM
neonracer1010's Avatar
neonracer1010
Default RE: just replaced head gasket, now whats wrong?
did you change your plugs by any chance?
Old Jun 24, 2008 | 03:36 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Who changed the head gasket? Almost sounds like timing is off. Advanced to far which is maing crappy low end with a better high end power.
Old Jun 24, 2008 | 03:37 PM
I_Ride_Neon
But yea spark plugs and wires that are bad will also do that. But I figured that was a basic thing you checked already?
Old Jun 25, 2008 | 01:32 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
check fuel pressure also.
Old Jun 25, 2008 | 02:33 AM
Tweaked_Neon's Avatar
Tweaked_Neon
my engine does the same thing...not to the extreme that yours is....but im having issues with electrical power in my car....it sometimes sputters and dies others not, im not sure if its the altenator crappin out or not....not really sure, but try testing your batter and altenator(load and just running) and test the amps to, see if there is any electrical power loss that way, and if not i got nothin:P
Old Jun 25, 2008 | 03:32 AM
JackMehoffer69's Avatar
JackMehoffer69
Heres what I'm wondering... Did you buy new head bolts or did you reuse your old bolts? old bolts stretch once they are used once and proper torque specs are impossible to get perfect on old bolts, chances are if you used the old bolts the seal isn't the greatest and you could have a leak which would cause improper compression and the thing to be a pooch.
Old Jun 25, 2008 | 05:10 AM
biigby's Avatar
biigby
I did replace the plugs and the plug wires
Old Jun 25, 2008 | 09:53 AM
JackMehoffer69
ORIGINAL: biigby
did you buy new head bolts and do the proper torque on them? first tighten to 25ftlbs then 50ftlbs then loosen then 25 then 50 again ?
Was the head surface and block surface cleaned properly? If even the slightest amount of dirt, grime or greaseis on the head surface you could have a small leak in your head gasket. Tell me more so we can cross this off the list!
