das, spud, jeremy, zach, anyone help, cant fix r/t!
Old Jun 25, 2008 | 07:24 AM
mulletman11's Avatar
mulletman11
Default das, spud, jeremy, zach, anyone help, cant fix r/t!
ok so about 2 months ago i fell asleep driving into ny and went into a ditch for about a quater mile b4 waking.
i hit a wall of dirt in my r/t.
lady behind me said i should have flipped, i diddnt know wtf was gogin on i was asleep
long story on a debeaded tire and new fuel line fitting and alignment were needed
get back into pa, 300 miles later
code 31 evap purge soleniod
called neonmike from the org, guy sold me my car, does wonders w neons
says to replace evap canister and all the lines attached to it
i did twice and code goes away for 300 miles or so
came on again for the 3rd time today, wtf do i do?
Old Jun 25, 2008 | 07:58 AM
spudsterier's Avatar
spudsterier
Default RE: das, spud, jeremy, zach, anyone help, cant fix r/t!
did you replace the selonoid located on the passenger side motor mount?
Old Jun 25, 2008 | 08:11 AM
mulletman11
the little thingy with the green cap, yea
the thing that pulls right out, it fits intot hte rubber hole, yea i chaged that
all parts from same year r/t
Old Jun 25, 2008 | 09:46 AM
JackMehoffer69's Avatar
JackMehoffer69
ORIGINAL: mulletman11
My hose that goes from the evap to tb isn't even connected on mine, but you may need it for emissions testing where you live. I don't see why the solenoid would be bad, if you hit the ditch I'd assume the evap canister is screwd up it sits right in the right front by the marker light.
Old Jun 25, 2008 | 10:57 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Did you unhook the vac lines and hook them up backwards or something?
Old Jun 25, 2008 | 11:17 AM
das2123's Avatar
das2123
You sure you hooked up all the lines correctly?
Old Jun 25, 2008 | 08:01 PM
mulletman11
possitivly, i hate to take off my bumper to get a pic but im pretty sure i did
the evap can was a little bent up, but i got a new one and those lines only fit on it one way
could it be the little sensors by the canistor?
Old Jun 26, 2008 | 08:44 AM
spudsterier
it could be the thinga ma jig ontop of the canister....
you made sure that the line from the fuel tank is still hooked up right? and that there are no broken wires or anything?
Old Jun 26, 2008 | 09:01 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
I don't see that part in my FSM
Old Jun 26, 2008 | 09:08 AM
spudsterier
if you look in the glossary, its under J....jig, thinga ma
not under T
