Installed MP PCM and new coil.plugs,wires
Old Jun 26, 2008 | 10:17 PM
brushedchrome's Avatar
brushedchrome
Default Installed MP PCM and new coil.plugs,wires
Was having a hell of a time with missfires at first before I figured out that the pigtail to the coil wasnt making a good contact. I took it apart and pinched the round recepticles (early 96 style) so that they would be tighter on the coil hookup and the problem was solved. Went to put on the underdrive pulley only to realize I couldnt pull the damn thing off without one of those special tools. My header showed up in a damaged box, missing some of the hardware. Ill contact Modern Performance tomorrow and get things ironed out.
Old Jun 27, 2008 | 07:45 AM
mulletman11's Avatar
mulletman11
Default RE: Installed MP PCM and new coil.plugs,wires
wat header did u buy again?
Old Jun 27, 2008 | 06:50 PM
brushedchrome
Its a Kirk long racing header.
Old Jun 28, 2008 | 01:02 AM
das2123's Avatar
das2123
ORIGINAL: brushedchrome
You don't plan on running the cat converter then do you?
Old Jun 28, 2008 | 03:59 PM
brushedchrome
Nope. But thats just between us Neon owners.
