whats da benefit?
Old Jun 28, 2008 | 11:53 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Default RE: whats da benefit?
The sohc intake manifold will not bolt up to a dohc head without fabrication. Even then, the dohc is superior for boost applications, and it can be ported. Get another dohc intake manifold and hog it out.
Old Jun 29, 2008 | 11:05 AM
spudsterier's Avatar
spudsterier
ORIGINAL: JackMehoffer69
I actually have never had that problem and my car came stock with the atx throttlebody cuz its an atx
on an atx car you dont notice the lighter spring becuase of the kickdown...when the car is in gear, more tension is put on the throttle cable....if you wanna know what it will fell like, just disconnect the kickdown cable and take the car for a ride
Old Jun 29, 2008 | 12:09 PM
JackMehoffer69's Avatar
JackMehoffer69
ORIGINAL: spudsterier
sure enough makes sense I tried it and your right.
