crane 14 or crane 20?? need to know
Old 06-29-2008, 10:27 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
Default RE: crane 14 or crane 20?? need to know
18's or higher and you will want to get an S-AFC to adjust the idle...
take you car and disconnect 1 of the fuel injectors....that is roughly the idle that you will have with 18's....go larger and disconnect 2 fuel injectors....
Old 06-30-2008, 01:03 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Ghost Neon 2 is offline
16's for drivability.
Old 06-30-2008, 11:56 AM
mulletman11's Avatar
mulletman11
mulletman11 is offline
wat is an sfact? or watever
Old 07-01-2008, 10:09 AM
spudsterier
s-afc
its an air fuel controller....allows you to adjust theair/fuel that you will need with bigger cams
Old 07-01-2008, 10:18 AM
mulletman11
i have an air/fuel gauge?
were do i get an air/fuel controller?
Old 07-02-2008, 10:05 AM
spudsterier
modernpeformance
http://www.modernperformance.com/pro...oducts_id=1172
Old 07-02-2008, 10:14 AM
mulletman11
would getting that require or delete the need for a air/fuel gauge?
Old 07-02-2008, 10:20 AM
spudsterier
no
Old 07-02-2008, 10:31 AM
mulletman11
it was not a yes or no question?
wtf hhaha
Old 07-02-2008, 10:35 AM
spudsterier
what kind of air fuel gauge is it? if it isnt a wideband then its a waste of money
but if it is, you dont really NEED it unless you go turbo
Quick Reply: crane 14 or crane 20?? need to know
