cat removal
Old Jan 25, 2005 | 06:13 PM
matt_guiver's Avatar
matt_guiver
Default cat removal
I want to take my cat off but i need to know how loud it will be. And if i t change anything in the system?
Old Jan 25, 2005 | 06:45 PM
casper's Avatar
casper
Default RE: cat removal
It will be a little louder, not that bad at all though. If you have emmisions testing in your area, be prepared to possibly fail, depending on how strict they are. I know in CT if they see there is no cat, you automatically fail wether or not the actual test comes back pass or not. I believe it is also illegal to remove any emmisions parts, although I would not think you would have too many problems, as how many cops pull you over and look under your car.
Old Jan 25, 2005 | 06:55 PM
matt_guiver
I dont know if they test that in Michigan or not. And cops love to pull me over for stupid stuff.
Old Jan 25, 2005 | 11:00 PM
casper's Avatar
casper
yeah doubt they wil look under your car. It won't make it that much louder.
Old Jan 26, 2005 | 04:49 AM
ewetho's Avatar
ewetho
First off after looking through your previous post I find you have a 97 which means you have a post cat O2 sensor that will get mad without a cat. So you have to either find a good O2 simulator or just get a bigger CAT if you are doing this for more flow. If your PCM does not see a good secondary O2 signal you will stay in Open loop and have a Check Engine Light.
Old Jan 26, 2005 | 06:03 PM
casper's Avatar
casper
I have seen the simulator on modern, I don't rember the price, but it wasn't that bad.
