Getting ready to swap a 2.4
Old Jul 20, 2008 | 02:08 PM
moparmandjh's Avatar
moparmandjh
Default Getting ready to swap a 2.4
Just ordered the mount adapter, udp, fmm insert, booger bushings, solid bobble, and 58# fpr. Getting my ps, and alt brackets when I get home off the road. This is going to be a lot of fun, I can't wait. Dave
Old Jul 21, 2008 | 02:46 AM
fsu182's Avatar
fsu182
Default RE: Getting ready to swap a 2.4
dont forget a clutch if ur smart
i put a race fmm insert in my car and holy crap does it vibrate when you start the car. a little bit at idle. but driving u dont get much over stock at all.
im saying this cuz ur solid bobble strut will do about the same.
anyway good luck. wish i'd have invested in the swap instead of all my bolt ons. oh well
Old Jul 21, 2008 | 08:03 AM
brushedchrome's Avatar
brushedchrome
Does the 2.4 rev up as high as the stock 2.0 SOHC? How much more power do you get out of the 2.4?
Old Jul 21, 2008 | 08:17 AM
moparmandjh
My clutch is only 6 months old, thanks for the suggestion though.
I'm only home 1.5 days a week so I can deal with the vibes, I used to run around in a 72 Charger with a 496 stroker and motor plates, can't be that bad.
Dave
Old Jul 21, 2008 | 12:39 PM
stealthneon420's Avatar
stealthneon420
The 2.4 is a dohc. It revs up to 7,200 in the neon. But I would not take it past 7 if it were me. They put out 150 hp I believe and about 150 tq. Compared to the neon it is a little bit more. To me its not really worth the swap. Enless you are doing it for other reasons then just running a stock 2.4.
Old Jul 22, 2008 | 03:02 PM
fsu182's Avatar
fsu182
ask anyone who has done the swap - they'll all tell you it was worth every penny.
20ft/lbs of torqueincrease over 2.0.no, the 2.4 does not rev as high as the 2.0.
my clutch has 2,000 miles on it and if i swapped to a 2.4 today id swap to a better clutch.
the car is going to be more apt to go, and go right now. which will be harder on a stock clutch.
it's just one of those things that would really suck to have break up on you.
im sure some ppl stuck with the stocker tho.
Old Jul 22, 2008 | 03:17 PM
neoncrazy101's Avatar
neoncrazy101
the 2.4L's out of the Sebrings and Stratus' put out 150hp and 160lbs. ft.
Old Jul 22, 2008 | 05:40 PM
fsu182's Avatar
fsu182
ok yeah its even more so there you go. my main point is it is worth IMO. very much so. and i plan on it eventually.
