03 dodge neon cluster swap
Old Jul 22, 2008 | 03:16 PM
Captansavaho's Avatar
Captansavaho
Default 03 dodge neon cluster swap
has anyone every swapped one in...i know they have a whole different setup...what all would you need would itbe the same thing as installing the srt-4 when doing the srt swap...any help would be appreciated
Old Jul 22, 2008 | 07:19 PM
DriftKing's Avatar
DriftKing
Default RE: 03 dodge neon cluster swap
Instrument cluster? As far as I know since early 80s Dodge/Chrysler has been plug and play for the standard wiring harness for all bodies so swapping a tach cluter for a non tach will just bolt right in, only harnesses you will need ot change are external units for auto or man trans under the hood. I had a 93 Daytona auto and everything was plug and play to swap from the auto to 5 speed including the linkage no cutting or welding (universal Unibody construction rules). If they kept that bit of genius id say find one and swap, I swapped a tach cluster to my 96 Neon without any extra wires or connections. I just wish the cluster to harness plugs were decent so the power stays on all the time, resoldered the board and it still cuts out, plastic harness clips are loose im pondering direct wiring it real soon and bypassing the plugs.
Old Jul 22, 2008 | 11:03 PM
spudsterier's Avatar
spudsterier
ORIGINAL: DriftKing
umm...ok
as far as i know, you will need all the wire harnesses and a whole bunch of other junk to do the swap
Old Jul 23, 2008 | 12:54 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Lmao.
Old Jul 23, 2008 | 02:24 AM
Captansavaho
anyone write up?
Old Jul 23, 2008 | 10:53 AM
das2123's Avatar
das2123
The 2nd gen clusters DO NOT operate the way our first gens do. They are bus data as opposed to our first gens. Their is no plug and play or easy way to do this.
Old Jul 23, 2008 | 09:11 PM
Captansavaho
yeah i figured there is no easy way...but is there a way
Old Jul 24, 2008 | 08:28 AM
das2123's Avatar
das2123
Not one that is worth it honestly.
