Anyone know how much to torque a rod cap?
Old Jul 23, 2008 | 08:49 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Anyone know how much to torque a rod cap?
lol well you know for next time
Old Jul 23, 2008 | 08:54 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Is that why my piston is loose now?
Old Jul 24, 2008 | 03:46 PM
fsu182's Avatar
fsu182
that additional 90 degrees of turning should only be done once. that is the same way the head bolts are. torque to spec then +90 degrees. one time.
the old bolt had came loose after only 2 minutes of running at idle.i tried to re-tighten it and it snapped immediatly. got it out and headed to the dealership (at the advice of the machine shop) for some new rod bolts.
old rod bolts are a great way towards a spun bearing, bent valves, scored cylinder wall, cracked head... all kinds of fun things.
Old Jul 24, 2008 | 06:06 PM
12 volt's Avatar
12 volt
you forgot the best one, thrown rod
Old Jul 24, 2008 | 06:53 PM
I_Ride_Neon
oops.
