painted the car :)
Old Jul 24, 2008 | 04:04 AM
96ACR*'s Avatar
96ACR*
Default painted the car :)
The whole roof and trunk and sides were peeling, so i decided to paint it
http://s269.photobucket.com/albums/j...0722081554.jpg
http://s269.photobucket.com/albums/j...722081554a.jpg
Old Jul 24, 2008 | 06:12 PM
12 volt's Avatar
12 volt
Default RE: painted the car :)
[sm=redx.gif]
Old Jul 24, 2008 | 09:29 PM
96ACR*'s Avatar
96ACR*
fixed
Old Jul 25, 2008 | 02:35 PM
das2123's Avatar
das2123
Nice.
Old Jul 25, 2008 | 04:07 PM
96ACR*'s Avatar
96ACR*
yea, good enough anyways, as long as its not peeling!
Old Jul 25, 2008 | 05:25 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
hell yeah! do you have any before pictures?
Old Jul 25, 2008 | 06:54 PM
civiceater88's Avatar
civiceater88
how u did u paint it becuz im about to paint my here very soon the same color also...any tips let me know please
Old Jul 25, 2008 | 08:36 PM
das2123's Avatar
das2123
Did you use a compressor and gun?
Old Jul 26, 2008 | 05:27 AM
96ACR*'s Avatar
96ACR*
I will post before pics on saturday
I used a compressor and spray gun for the paint, i presure washed all the paint that i could off, then i started with 100 grit sand paper on a 6 inch round air sander, all the bad spots that were peeling i took right down to metal, and the rest i just feathered out, then i switched to 220 grit and featherd it out more. i removed all my lights, bumpers, door trim and moldings, winshield washers and sprayers, roof trim. i then blew all the sanding dust off the car and wipped it down with a wax and grease remover, i tapped all my windows up and wrapped the tires in plastic, i left my doors open and used paper to tape off the cab with so i could spray the door jams. i then sprayed my primer on, sanded it down with 400, washed it again nd then sprayed another coat of primer, then i sanded it down with green scotch brite pads, washed it and then i sprayed my white on. i used acrylic enamel paint. Make sure before you spray the primer on that there are no shiny spots on the paint thats left on the car.
Biggest tip i can give is take your time!!! the more time you put in the better it will look, painting a car properly is a pain in the ***. but rushing and doing it half assed wont help either
Old Jul 26, 2008 | 07:49 PM
DOHCgarrett t3
I like it. I was in the process of doing my car, but then it got stolen so i wasnt worried about it after that.
