rims are rubbing!!!
Old 07-25-2008, 02:40 PM
iwalton63's Avatar
iwalton63
iwalton63 is offline
Old 07-25-2008, 05:48 PM
Captansavaho's Avatar
Captansavaho
Captansavaho is offline
Default RE: rims are rubbing!!!
thats something completely different...look at the spacer you should put on vs that one...the one you are putting on is only 5mm...look how thick that one is in the link givin inside the link you gave
Old 07-25-2008, 07:33 PM
fsu182's Avatar
fsu182
fsu182 is offline
if there is even a tiny defect in the spacer it leads down a path of pre-worn tires, noisy suspenison, broken parts. its just not good. i wouldn't trust an ebay spacer. i love ebay, i get parts off of it all the time. but its such a tiny part to let mess up so much stuff.
Old 07-25-2008, 08:42 PM
das2123's Avatar
das2123
das2123 is offline
I dont like the idea of using spacers at all. Does the rim you have come in a smaller offset?
Old 07-26-2008, 07:26 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Ghost Neon 2 is offline
Rubbin is racing [/days of thunder]
Spacer comes loose and shears off your wheel stud. Seen it happen on a stock caddy. Find another way.
Old 07-26-2008, 09:54 PM
das2123's Avatar
das2123
das2123 is offline
Find the correct offset or get the Offset Rear Suspension Tension Rods.
Old 07-26-2008, 10:08 PM
iwalton63's Avatar
iwalton63
i just went ahead and order the offset rods. just to be safe. thanks for the help tough
Quick Reply: rims are rubbing!!!
