rims are rubbing!!!
Old 07-24-2008, 02:05 PM
iwalton63's Avatar
iwalton63
iwalton63 is offline
Default rims are rubbing!!!
I got new rims and tires ( 205/40/17 ) and the back two rub on the trailing links(tension rods)
how do i fix this? spacers? new links or what
Old 07-24-2008, 02:14 PM
Captansavaho's Avatar
Captansavaho
Captansavaho is offline
Default RE: rims are rubbing!!!
it depends what the offset is on the rims...maybe you do need spacers
Old 07-24-2008, 02:43 PM
iwalton63's Avatar
iwalton63
what is my other option beside spacers?
Old 07-24-2008, 02:51 PM
Captansavaho
i would think only spacers...idk if there is anything else you can change
Old 07-24-2008, 03:37 PM
fsu182's Avatar
fsu182
fsu182 is offline
offset trailing links then. they only cost you $70 after the core charge.
http://neongoodies.com/Goodies/Rear_...ion_Rods.shtml
Old 07-24-2008, 08:06 PM
iwalton63's Avatar
iwalton63
where do you buy the spacers from, i have looked around and cant find them.
Old 07-25-2008, 10:35 AM
fsu182's Avatar
fsu182
fsu182 is offline
Old 07-25-2008, 12:14 PM
vipersforsale's Avatar
vipersforsale
vipersforsale is offline
or ebay, they are dirt cheap on there... you will only need like 5mm difference anyway since they just barely rub.
Old 07-25-2008, 02:05 PM
iwalton63's Avatar
iwalton63
ok so i have heard some bad things about the spacers. what do you guys think? should i still get them?
Old 07-25-2008, 02:30 PM
Captansavaho
what is bad about them?? i wouldnt think they put anymore stress on the studs or anything its only a 5mm difference.
Quick Reply: rims are rubbing!!!
