Starter question
Old Jul 24, 2008 | 11:57 PM
DustDevil33's Avatar
DustDevil33
Default Starter question
So the starter just crapped out in my car and my neighbor has a wrecked neon he said I could take the starter from. The question is this. Is there a difference between a starter for an MTX car and one with an ATX? Or are they the same. The one in the parts car was new before he wrecked it so I know it's good, but his is an atx trans and mine is mtx. Thanks for replies in advance
Old Jul 25, 2008 | 11:38 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: Starter question
As far as I know they are the same. I think the years will be the only thing. They may have used different style clip for the remote wire on it. Buts thats an easy fix.
Old Jul 25, 2008 | 01:40 PM
Ghost Neon 2's Avatar
Ghost Neon 2
2G starters are larger.
Old Jul 25, 2008 | 02:26 PM
I_Ride_Neon
2g 2nd gen? They actually save you space on the 1st gen.
Old Jul 25, 2008 | 02:39 PM
das2123's Avatar
das2123
ORIGINAL: I_Ride_Neon
Thats what I understand as well. Hence the reason you need a 2nd gen starter if you run the magnum intake on a 1st gen.
Old Jul 25, 2008 | 03:01 PM
I_Ride_Neon
They are actually the same size. They just put the solenoid in a different spot. Its lower. I think thats what its called? The thing the power hooks into.
Old Jul 25, 2008 | 05:41 PM
neoncrazy101's Avatar
neoncrazy101
1st gen starters aren't different. I've put 95 starters in 97's and 96's in 97's and 95's. so pretty sure its the same.
Old Jul 25, 2008 | 08:48 PM
das2123's Avatar
das2123
Plugs are different. They changed in 98...95-97 are the same.
Old Jul 25, 2008 | 09:29 PM
neoncrazy101
thats odd. you would of thought they changed them in 97 since they did with all the other sensors lol.
