Neon SOHC TURBO
Old Jul 28, 2008 | 09:18 PM
ottoretto's Avatar
ottoretto
Default Neon SOHC TURBO
Hello everyone.
Well i got a question, i have a 98 Neon SE SOHC, i worked the head, i installed new pistons, and now the compression ratio its 11,1:1 when the stock its 9.8:1, so i wanna know how much pressure can resist the stock engine with a turbo i mean the top pressure, cuz i wanna install a turbo and i need to know that to see how much pressure i can put into the engine with the turbo
thanks a lot
Old Jul 28, 2008 | 09:58 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Neon SOHC TURBO
you dont want to turbo a high compression engine. go NA since you already have higher compression pistons
Old Jul 28, 2008 | 10:47 PM
neoncrazy101's Avatar
neoncrazy101
yeah if you want turbo you need like what an 8:1 ratio or something like that?
Old Jul 29, 2008 | 08:47 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Ideal compression for almost any forced induction engine is 8.5:1. If you really have the mods you say you do, I would stick a more aggressive cam in there, or tear your motor down and put some lower compression pistons in if you are stuck on a turbo.
Old Jul 29, 2008 | 10:05 AM
spudsterier's Avatar
spudsterier
high compression with a turbo is a big no-no....you can do it, but it wouldnt be very safe for the motor if you plan on running anything higher then 5 pounds of boost
Old Jul 29, 2008 | 01:48 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
less room for tuning also with a high compression forced induction aplication... less error means more chances of car going boom boom BOOM
Old Jul 29, 2008 | 05:24 PM
DOHCgarrett t3
you would also have to put a lot more fuel in there to combat pre-detonation
Old Jul 30, 2008 | 03:58 PM
ottoretto's Avatar
ottoretto
thanks a lot, i got high compression ratiocuz i got plane pistons, the stock engine got low comp. pistons and the comp ratio its 9.8:1, i know that i got to puta lot of fueland i the solution its big injectors, but my questions its how much pressure resist thestock engine,i mean with 9.8:1 C/R, im planing start to 5 or 8 psi not much so i need yar help with that question
thanks a lot bros
