unanswerable or what
Old Aug 16, 2008 | 07:53 PM
opie9797's Avatar
opie9797
Default unanswerable or what
1995 neon sohc when driving on bypass or tollroad when i get off car stalls but starts back up and then every time i take my foot off the gas stalls again no check engine light nothing i dont know wha it is do you ??????????
Old Aug 16, 2008 | 10:40 PM
das2123's Avatar
das2123
Auto or manual?
Old Aug 17, 2008 | 01:47 PM
opie9797's Avatar
opie9797
automatic pos
Old Aug 17, 2008 | 04:10 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
when was the last time the car was tuned up?
Old Aug 17, 2008 | 07:35 PM
fsu182's Avatar
fsu182
can you or someone you know check your fuel pressure?
just some personal exp - when my car did this same thing the ground wire coming off of the fuel pump had partially corroded and finally broke off all together. it took a long time to figure out.
my car is a little different than yours cuz its a 99 and an mtx. but fuel pressure is still something to check off the list of possibilities
Old Aug 18, 2008 | 08:09 AM
das2123's Avatar
das2123
So the car shuts off in the idle position correct? Probably not getting enough fuel.
Old Aug 18, 2008 | 08:40 AM
opie9797's Avatar
opie9797
never thought about fuel cause i can drive it all day in the city and never have a problem but tune up was about five yrs ago but i only put three to four thousand miles a yr on it but i get off the highway and when it dies the only thing to get it back running right is put it in nuetral and crank it to four thousand rpms for a sec and some time it takes a few times for that i will check the fuel any one got more ideas
Old Aug 18, 2008 | 12:26 PM
das2123's Avatar
das2123
Possibly a bad TPS.
Old Aug 18, 2008 | 06:48 PM
fsu182's Avatar
fsu182
tps should throw a cel. i just dealt with a bad one of those too. my car idled just fine, but if you pulled out right away and didnt let it "warm up" a little it would miss, sputter, and carry on while you accelerated.
really sounds like you arent getting enough fuel at idle to me. my car acted exactly the same. i tore it down to reset the timing in -5 degree weather and everything before i decided maybe it was my pump.
i got underneath the car, saw that damn ground wire. replaced it and the car fired up after three seconds of cranking to build fuel pressure.
Old Aug 19, 2008 | 09:02 AM
das2123's Avatar
das2123
So should alot of other problems, but they don't.
