Back brakes creak no matter WHAT I do, help...
This issue has me tearing my hair out. About 2 months ago, I completely replaced my rear brakes- shoes, drums, and even the hardware, because they kept making a very loud rhythmic creaking noise whenever I stopped. The rhythm was directly related to my speed, the slower my wheels turned, the slower the creaks, so it's definitely something rubbing in there. It sounded kinda like bed springs creaking. EEE-er-EEE-er-EEE-er. Very embarrassing in traffic. All was well until today- the noise is starting up again. I cannot afford to convert to rear discs right now or else I would, so I have to figure out what is causing this.
Has anyone else had this problem? They're brand new brakes! It did recently rain here, could that have something to do with it? I'm going to try cleaning them really good but any advice or ideas will be greatly appreciated.
neon brakes make noise when they get wet or get moisture in there. you can try to lube the hardware with brake hardware lube (the stuff you put on the sliders) i use syl-glyde. use very little. also, make sure you install the brake adjuster hole plugs that come with the hardware kits, that will help keep moisture out.
