Intermittant speedometer
Old Sep 4, 2008 | 12:19 AM
buenymayor's Avatar
buenymayor
Default Intermittant speedometer
I just bought a 96 Neon 2.0L 5 speed. The speedometer is intermittant. I can bang on the dash and get it to start reading sometimes, but it needs fixed. Any ideas on where to start?
Old Sep 4, 2008 | 03:34 AM
buenymayor's Avatar
buenymayor
After doing a search on here, I've got enough info to at least check things out. If I have any trouble, I'll be back!
Old Sep 5, 2008 | 12:54 PM
holliwud's Avatar
holliwud
i'm not sure what they call it but, if you go to the shop and let them know they can fix it. its under the hood. i had the same problem. it becomes loose and just doesn't spin right to give a accurate reading to the speedometer.
pm das2123, he'll probly tell you where its at so u could tighten it and save money not going to the shop.
Old Sep 7, 2008 | 09:51 AM
craigsharp's Avatar
craigsharp
It's probably one of two things. Either your solder points on the back of the cluster needs to be re-soldered or you just need to tighten down the bolts that hold he speedo in place. The former was my problem.
Old Sep 7, 2008 | 01:21 PM
DustDevil33's Avatar
DustDevil33
My car had the same problem. When I pulled out the cluster, I found that the plugs were loose and the tabs that held them in place were worn. So I trimmed the tabs off and glued the plugs in place. Haven't had a problem since
Old Sep 7, 2008 | 09:01 PM
schrack's Avatar
schrack
I had the same problem with a 96 neon sohc. I took cluster out. Where the wires run through the dash. I drilled a small hole & pop riveted the conector so it would not move in the dash, & reconected to the cluster. It works almost 95% of the time now.
Old Sep 8, 2008 | 03:24 AM
kabuk1's Avatar
kabuk1
I had the problem where ALL my guages would randomly die. Nearly had a heart attack the first time it happened. Turned out it was the solder joints. I dismantled it & re-flowed the solder, and they've worked flawlessly since. Try doing that. It's MUCH easier to do than it sounds.
Old Sep 8, 2008 | 08:15 AM
schrack's Avatar
schrack
I tried the solder method first , it did not help me any. Thats when i figured the connector was moving & pop riveted it to keep it from moving inside the dash cluster.
Old Sep 8, 2008 | 01:24 PM
das2123's Avatar
das2123
Sometimes you need to add solder. Try reflowing it again and make sure you see them change color.
https://dodgeforum.com/m_179505/tm.htm
Old Sep 8, 2008 | 05:28 PM
schrack's Avatar
schrack
Well i did not add any solder, didn't know i was supposed to. I did heat the old solder points until they changed color. Like i said earlier the pop rivet works pretty good to keep the connector coming through the dash from moving.
