sucked up some water.....
Old Sep 16, 2008 | 12:53 AM
iwalton63's Avatar
iwalton63
what do you mean turn it with the starter?
sorry if that is a dumb question
Old Sep 16, 2008 | 12:59 AM
12 volt's Avatar
12 volt
turn the crankshaft in the direction of engine rotation or turn the key and see if the stater can
Old Sep 16, 2008 | 01:10 AM
iwalton63's Avatar
iwalton63
alright and what happens after that like maybe water shoot out, maybe not what will this prove ?
Old Sep 16, 2008 | 01:53 AM
12 volt's Avatar
12 volt
it will let you know how much water is in the cylinders and get the water out.
Old Sep 16, 2008 | 02:04 AM
iwalton63's Avatar
iwalton63
alright thanks.
well tomorrow night i will do all that. and keep you posted, when i need more help.
thanks alot man .
Old Sep 16, 2008 | 06:08 PM
bone33's Avatar
bone33
you know how an engine works right? it takes in air/fuel and compresses it in the combustion chamber and you know that water cannot be compressed.... so that said if water gets in there and it wont compress then something has to give, so what happens is the rods break or the valves or something else breaks to let the water escape. you have check for water in there by removing the spark plugs and cranking it with the starter.
Old Sep 16, 2008 | 09:51 PM
das2123's Avatar
das2123
If you tried to crank the car with the water in it and now only it clicks....you most likely snapped a rod.
First thing you should have done, was pull the plugs and crank the engine over. Then pull the TB and intake manifold off and drain any and all water.
Drop the oil pan and have a look and see what you see.
