Maybe Clutch, Not sure!!! :(
Old 10-18-2008 | 02:21 PM
awsgrayrd's Avatar
awsgrayrd
Originally Posted by I_Ride_Neon
The modular clutch does NOT need to be machined. You will need no machine work with the modular clutch. Reason: The non modular clutches use the same flywheel each time. The flywheel usually is machined otherwise it will wear the clutch down fast and unevenly. The modular clutch comes as the clutch, flywheel, pressure plate as one piece. New. So no need for machine work.
I appreciate the responce that does take a load off my shoulders. Thanks everyone I'll let you know the end resuls tonight.
Regards,
AWS-Grayrd
Quick Reply: Maybe Clutch, Not sure!!! :(
