any ideas? on cruise control
Old Oct 16, 2008 | 05:13 PM
ajpranger's Avatar
ajpranger
Default any ideas? on cruise control
my 95 neon is equipped with cruise control but when i mess with the controls nothing happens. i touch the on button the light never comes on. it doesn't do anything. is this a typical problem with all neons or do i just need to take it in and have it looked at?
Old Oct 16, 2008 | 11:11 PM
streetracer88's Avatar
streetracer88
you should look at see if the cable is connected its right on where your throttle body is and make sure its connected but if it is then yah i would get it looked at
Old Oct 16, 2008 | 11:41 PM
spudsterier's Avatar
spudsterier
our neons dont have a cruise control light.
either way, if the cruise isnt working, its generally either a blown fuse, bad vaccum actuator, or a bad vaccum line sumwhere
Old Oct 17, 2008 | 12:43 AM
streetracer88
or the cable is unhooked on the throttle body....not to argue with you spud...
Old Nov 10, 2008 | 04:23 PM
ajpranger's Avatar
ajpranger
okay so i checked and the fuse is okay and the cable is hooked up to the tb. but i don't know anything about vacuum actuator or lines, is there anyway i could tell which it is.
Old Nov 10, 2008 | 05:18 PM
HellCat1988's Avatar
HellCat1988
The vacume actuator is a pot about 4 inches round with a metal cap on one end that the cable for the cruse comes out of. Look on your tb and follow the cable that is attached to the bottom of the throttle arm over to it. After you've found it, check the hoses and such to make sure that it's hooked up properly.
