Any one know how to take the A/C out of a 97 coupe neon?
Old Nov 3, 2008 | 09:00 PM
messedupsn's Avatar
messedupsn
Default Any one know how to take the A/C out of a 97 coupe neon?
i gutted the inside of my car after the airbags went off and broke my dash and shattered my two door windows. i had to replace the sub-frame, and boy was that quite a job. anyway i need to get the a/c out and can't quite figure out how to do it, i will post pics either tonight or tomorrow.
Old Nov 3, 2008 | 11:09 PM
spudsterier's Avatar
spudsterier
which part of the a/c do you need to get out?
Old Nov 4, 2008 | 12:33 AM
messedupsn's Avatar
messedupsn
lol the whole thing, pics are here
Old Nov 4, 2008 | 09:01 AM
spudsterier
so your trying to get out the box?
Old Nov 4, 2008 | 08:37 PM
messedupsn's Avatar
messedupsn
and if i can get the lines out and stuff through the firewall out too and the compressor and all that jazz, i just need to know where everything is.
Old Nov 5, 2008 | 08:32 AM
das2123's Avatar
das2123
Just start pulling out bolts and nuts. You have it gutted nicely, so it shouldn't be too hard to see everything.
Old Nov 6, 2008 | 10:09 PM
messedupsn's Avatar
messedupsn
well i was told i have to discharge the freon first but where is the valve at? i can't run the compressor while doing it because i removed the controls already.
Old Nov 7, 2008 | 12:01 AM
das2123's Avatar
das2123
Legally, you can't discharge the refrigerant yourself.
Old Nov 9, 2008 | 12:11 AM
messedupsn's Avatar
messedupsn
well, what if i were to "accidentally" discharge the a/c how would that work?
Old Nov 10, 2008 | 01:05 AM
DOHCneon95's Avatar
DOHCneon95
legally you cant discharge the refrigerant into the air....if you discharge it into a bottle with an anti leak seal you can(some shops do it)....but to discharge the freon locate the port and screw the bottle onto the port and the pin will depress and release it into the bottle or
