so a couple weeks ago i thought my starter went. when i turned the key, it just clicked. everything worked so it wasnt the battery or anything. so i took off the starter and took it to auto zone. it worked fine there. so i cleaned up the fittings and it started working. so today it did it again. i dont think it needs cleaned. could it have been something else the time before? thanks in advanced for all who help
If it worked there i would assume battery my friend. I don't care if it shows 12.6 volts or whatever. If it pushes a load on the bench it probably is fine. If it only clicking the the first thing we think of at the shop is battery. Might be time.
i just bought a battery in september. and i havn't ever left anything on. unless somthing is draining it. plus everything was working like the radio and stuff. could it still be the battery?
I had a starter go bad on my Geo Metro once, and it was an intermittent problem. It just clicked when I tried to start it, but the next morning it was working fine.
Starters can work intermitantly. I would think its the starter. Bring the car to autozone and they can test the battery. Alternators generally work or don't they don't usually work sometimes and not others.
