Water pump
Old Dec 4, 2008 | 08:59 PM
mread's Avatar
mread
Question Water pump
I am looking for a little advice. I have a 1998 neon (DOHC) and the water pump needs replacing. While looking at my Chiltons' manual I found that it states I need to perform a "timing relearn procedure" with the use of a DRB or equivalent scanner. I found a used scanner on e-bay for $499, this is a little more than I want to spend. My question is this, is the timing relearn procedure really necessary or is there a way around it? Thanks for any help you can give me.
Old Dec 4, 2008 | 09:07 PM
neoncrazy101's Avatar
neoncrazy101
um... as far as i know (I have all SOHC's), all you have to do is make sure all the timing marks line up. thats all.
Old Dec 5, 2008 | 09:11 AM
justinsanders's Avatar
justinsanders
well i didnt do that but my manual did say to and i just replaced my timing belt and water pump i just made sure to set the timing marks almost perfectly as good as i could get it and it seems to be fine
Old Dec 5, 2008 | 01:03 PM
spudsterier's Avatar
spudsterier
as long as the marks line up then your good to go
Old Dec 6, 2008 | 03:52 AM
DOHCneon95's Avatar
DOHCneon95
they do help but as long as you line up your marks your fine
