98 neon ACR help please
Old Dec 19, 2008 | 07:16 PM
slo_neonRT's Avatar
slo_neonRT
Default 98 neon ACR help please
I have a 98 neon acr i changed out the fuel pump thinking the fuel filter would come as part of the fuel pump but i was just told today that the fuel filter is inside the pressure regulator witch is on top of the fuel pump cap on the out side of the tank if some one who might no can help me i need to no cuz if what the guy said is true i need to change is cuz it has 211000 miles on it and that would be the reason of my slight power loss......hopefully
Old Dec 21, 2008 | 05:23 AM
coocoobird's Avatar
coocoobird
Ya its located on the top of the fuel pump assembly and yes the fuel pressure regulator and filter are built together. You can get one Online or at the dealer i believe seperately. I believe there is also a prefilter that is a bigger canister also on some.
Old Dec 22, 2008 | 01:49 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Make sure you get the right one. Sounds like you have a plastic tank. Last time I tried to get one it only took them 3 tries. I doubt that is whats giving you a slight power difference.
Old Dec 22, 2008 | 02:39 PM
das2123's Avatar
das2123
Did you check your fuel pressure before attempting to replace it?
Old Jan 9, 2009 | 12:14 AM
slo_neonRT's Avatar
slo_neonRT
yea my fuel pressure was low not to low but lower then wut it should be for my motor i put a 58psi pressure regulator on it from modernperformance it didnt fix the prob. iam preaty sure its my piston rings i did a dry amd wet compression test and they where at about 210 and with a spoon full of oil they would go past 300psi thats with 5 revoulutions of the motor of course thats how i was told the best way was to test it
