does any one now?
Old Jan 1, 2009 | 07:46 PM
slo_neonRT's Avatar
slo_neonRT
Default does any one now?
what site i cand buy a good performance fuel rail for my 2.0 dohc 98 neon the only sites i no of are modernperformance and howellautomotive and they dont have fuel rail they use to have them on ebay for my car but i just looked and they dont have them no more plz if any one can post some sites
Old Jan 1, 2009 | 08:22 PM
bad venge's Avatar
bad venge
Section Moderator
Is that the 420A engine ??? If so
http://catalog.disturbingmotorsports...oducts_id=1037
Old Jan 1, 2009 | 08:30 PM
spudsterier's Avatar
spudsterier
no it isnt a 420a engine.
what exactly are your needs of an aftermarket fuel rail?
FYI: it helps to use punchuation
Old Jan 2, 2009 | 08:27 AM
das2123's Avatar
das2123
WHAT?
Here you go slo_neonRT...
http://www.lfsracing.com/proddetail.php?prod=9505FRAILS
Old Jan 2, 2009 | 10:34 AM
spudsterier
Originally Posted by das2123
WHAT?
hahaha
Old Jan 6, 2009 | 08:58 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Awesome craftsmanship on his parts. Bought a rail and 2.4L mount adaptor from him. Strongly recommend getting one. Fast shipping to boot.
Old Jan 8, 2009 | 11:56 PM
slo_neonRT's Avatar
slo_neonRT
yea its the 420a motor and i need more fuel becouse i have 12 to 1 comp. and iam getting spark knocking i got 11 to 1 pistons my heads shaved and has been p&p'd so i was looking for a bigger fuel rail i put in a better pressure regulature and it got rid of some of my bottem end pinging it only happens at lower rpms at higher rpms it goes away so iam tryign to uprgade my fuel and spark but i have recently fryed my piston rings so iam ganna replace those and put a thick *** head gasket on to help lower the comp. so maybe i could put a 75shot on it
Old Jan 9, 2009 | 05:33 PM
spudsterier
so you swapped the engine from an eclipe in your neon? exhaust/intake and everything?
did you use the eclipse tranny too?
thats pretty cool..
i bet it was a pain in the *** to pipe in the exhaust seing as it would run around the front of the motor
Old Jan 14, 2009 | 11:22 PM
slo_neonRT's Avatar
slo_neonRT
the 420a motor comes in all 95-99 non turbo eclipses and it also comes in ur 1st gen neons the motor is the same but the intake manifold and exhaust are swaped like u said the eclipse motor puts out like maybe 5more hp with the setup they have iam not sure how much more but i was told they do put out more hp but not by alot my acr puts out 150 stock and iam not sure if u can do the eclipse 420a swap or not iam sure u can but it would be a pain u would prolly need a eclipse radiator and fans
Old Jan 15, 2009 | 07:48 AM
das2123's Avatar
das2123
That is a big myth! The Dodge DOHC engine IS NOT A 420a engine, nor has it ever had the 420a engine in it. The 420a engine is Mitsubishi's engine code for it's DOHC that it borrowed from Chrysler (who designed the ECC <----DOHC engine code for the neon), reversed the head and dropped it into the Eclipse. So the correct way to say it, would be that the Eclipse has the Neon engine in it.....but people don't say that because the Eclipse was used in the Fast and Furious and not the neon
