Help Wiring Amp :)
01-02-2009, 07:37 PM
on
Help Wiring Amp :)
Hello, I need some help on getting the power wire Through the Firewall, were is the best place to put it through? I have a 97' Neon
-Thanks!
01-03-2009, 03:38 AM
on
i just went thru the rubber groment that the engine wiring harness goes thur. its on the drivers side
01-03-2009, 09:59 AM
thats the same place i always go through...just cut a slit in the gromet and push the wire through
01-04-2009, 12:10 PM
on
or if the cars an auto through the hole were the clutch cable goes
01-04-2009, 12:31 PM
on
i drilled a hole through the firewall and used rtv to seal it after i was done
