newbie question
Old Jan 13, 2009 | 01:24 AM
neongreen's Avatar
neongreen
and does anybody know the bolt pattern? thanks
Old Jan 13, 2009 | 09:03 PM
neoncrazy101's Avatar
neoncrazy101
bolt pattern for the head? Since the lines are frozen, then I would let it thaw out some and see if any water is coming out of the block. Just to make sure. Hopefully there was atleast some coolant in there so it didn't completely freeze inside the engine.
Old Jan 19, 2009 | 05:49 PM
?plymouth?'s Avatar
?plymouth?
hey. its neon green. sorry i haven't posted back i had a problem with my password and had to make a new username. well i found out its the water pump and as soon as i put that in im on the road again....
and one more little question. i own a jeep also and i just put all my money into it... will that happen with this car also?
Old Jan 19, 2009 | 06:05 PM
ajpranger's Avatar
ajpranger
honestly depends on what you are wanting to do with it. just as a basic daily driver, probably not. soup it up like most of us on here yes probably money will be put into it, notice i did not say invested but put. right now my 1995 neon has about 4000-4500, however i am not planning on selling and i am slowly souping it up. hope that answers your question
Old Jan 19, 2009 | 10:17 PM
weatherman212's Avatar
weatherman212
A little maintenance goes a long way, change the oil on time, make sure that the Thermostat is good, and make sure it has some good antifreeze and a good battery, and it shouldn't give you a problem.
Old Jan 21, 2009 | 03:08 PM
?plymouth?'s Avatar
?plymouth?
well i think im just gonna use it as a daily driver cause i want to lift my jeep. but after that i might put money into it... the only problem is its automatic
