Another newbie question
Old Jan 13, 2009 | 09:41 PM
mxr296's Avatar
mxr296
Default Another newbie question
I just purchased a 96 DOHC and it has pretty bad rodknock
does this happen in alot of the first gens?
Old Jan 13, 2009 | 09:49 PM
GLXRustang's Avatar
GLXRustang
Maybe with abused 1st gens. Does the knock persist or does it only happen at idle? In eihter case drive slower. Mine will do it in the morning then disappear and I beat on mine alot.
Old Jan 13, 2009 | 09:53 PM
mxr296's Avatar
mxr296
its really persitant
it idles pretty rough
but the knock comes in bad at mid to higher RPM
Old Jan 13, 2009 | 11:35 PM
I_Ride_Neon's Avatar
I_Ride_Neon
A rod knock, piston slap, and lifter noise are all different. Piston slap and lifter noise usually go away after warming up. If you have a rod knock I would try a new bearing on it. You may be lucky.
Old Jan 14, 2009 | 12:40 AM
mxr296's Avatar
mxr296
i dont think that'll work
kas the guy i bought it from drove on it like that and its pretty bad
so i think the rods are probly warped =/
is it difficult to replace the rods?
Old Jan 14, 2009 | 10:13 AM
spudsterier's Avatar
spudsterier
usually a bad rod knock in these cars is due to a spun bearing...in that case, the crank will have to be resurfaced or replaced, oversize bearings will most likey have to be purchased, and atleast one of the rods replaced...
Old Jan 14, 2009 | 04:19 PM
mxr296's Avatar
mxr296
ok thank you
i eventually wanna turbo this car so do you guys think i should fix this engine or go pull out a junkyard engine
i wanna use the same type of engine becaues i dnt really have enough experience to do the srt-4 swap
