Main Computer Whistles While it Works...
Old Jan 15, 2009 | 05:27 PM
oobical's Avatar
oobical
Angry Main Computer Whistles While it Works...
i know this sounds kind of funny but it is starting to get seriously annoying and at 50 bucks a pop its getting pricy and time consuming to try to find new computer modules. i have a 1995 Dodge Neon Highline with the computer number 123 and after a ride i will start hearing a whistle coming from the computer, the first computer was toast i couldnt read or clear codes from it, and the second i could read and clear codes but the whistle in the first one wasnt as loud as the whistle in the second computer is. what makes it whistle and how can i make it stop. and so you dont have to ask the 123 computer is a dealer only part and very pricey compared to the others that are around 275-290 bucks.
Old Jan 15, 2009 | 07:00 PM
spudsterier's Avatar
spudsterier
the whistle is normal...
every neon ive ever owned (which the total is in the 20's right now) has done that
Old Jan 15, 2009 | 10:18 PM
weatherman212's Avatar
weatherman212
Just so that you hear it from more that one person; yes it is normal, and everything is fine. Some Neons are just louder than others.
Old Jan 16, 2009 | 03:39 PM
das2123's Avatar
das2123
I have heard it has something to do with checking the O2 sensor when certain parameters are met.
Old Jan 17, 2009 | 10:29 PM
oobical's Avatar
oobical
i would have to say that about wraps everything up, because the whistle doesnt seem to affect anything, the new computer maybe louder but atleast i could get the codes cleared to turn off the check engine light.
Old Jan 18, 2009 | 12:20 PM
Spawne32's Avatar
Spawne32
the whistle is from failing capacitors in the ECU
Old Jan 18, 2009 | 02:59 PM
das2123's Avatar
das2123
Where did you hear that?
Old Jan 18, 2009 | 07:40 PM
Spawne32's Avatar
Spawne32
computer engineering lol failing capacitors on a motherboard usually give off a nice whistle as they go bad
Old Jan 19, 2009 | 08:04 AM
das2123's Avatar
das2123
I knew I read this somewhere before. From the .org's FAQ's...
The PCM (Powertrain Control Module) may emit a high-pitched "whistle" sound after the engine is shut off. The sound may last up to eight minutes. The noise can vary in pitch and intensity from one PCM to the next and with changes in temperature and battery system voltage. This noise is due to the PCM being "powered up" after ignition-off to enable a diagnostic routine for the O2 heater operation. This diagnostic routine will only occur when certain parameters are met, which include engine operating temperature and how long the vehicle has been driven. This noise may also be heard with the ignition on and engine running, but is usually muffled by the normal engine operation sounds.
Replacing the PCM may seem to eliminate the noise for a period of time, but this is only due to the system not meeting the qualifying parameters to run the ignition-off diagnostic routine. THIS IS AN OPERATIONAL CHARACTERISTIC OF THE PCM AND NO REPAIRS SHOULD BE ATTEMPTED.
Old Jan 19, 2009 | 08:09 AM
Spawne32's Avatar
Spawne32
interesting, the PCM in my neon has never whistled....ever lol
