wtf! i keep fryin coil packs left and right
Old Jan 21, 2009 | 10:40 PM
justinsanders's Avatar
justinsanders
Exclamation wtf! i keep fryin coil packs left and right
this is about the 4th coil pack that i've mysteriously fried. the car misses at passed 1/4 throttle and at idle but anywhere in between its fine. i'll backfire real bad out the intake if you floor it at a low rpm in gear. but everytime i replace the pack it'll be fine. it fries the pack whenever i go around beatin on the motor and steppin on the throttle but that shouldn't keep killin the coil packs. its really frustrating what could be the problem
Old Jan 22, 2009 | 02:03 PM
das2123's Avatar
das2123
How is the wiring to the coil pack?
Old Jan 22, 2009 | 09:08 PM
justinsanders
i actually had to extend the wires to the coil pack for the motor swap so i just added like 10 inches to all 3 wires and taped them up real good. however one time the wires fell on my header and melted through so i repaired it with tape and re routed them but they should be fine
Old Jan 22, 2009 | 10:58 PM
das2123's Avatar
das2123
Did you solder the wires?
Old Jan 23, 2009 | 11:46 PM
justinsanders
nope just twisted them and taped them individually. its actually seeming to be gettin better now after bein easy on it. i swapped on another used coil pack and it was doin the same thing so this time it might not be the coil pack. maybe a bad camshaft or crank position sensor or knock sensor idk. all i have a code for is egr flow but im usin the stock computer now.
Old Jan 23, 2009 | 11:47 PM
justinsanders
my teacher also said to check my motor to body grounds. and now that i think about it all i have is two motor to body grounds one on the back of the head and one at the bottom motor mount. is that enough?
Old Jan 26, 2009 | 07:09 PM
justinsanders
im so thinking about buyin a brand new wiring harness and all new sensors. where can i get a brand new harness not used? and can i buy all the sensors in some sort of package deal somewhere? cuz im tired of tryin to diagnoss the prob.
Old Jan 26, 2009 | 08:55 PM
das2123's Avatar
das2123
A brand new harness will be real expensive from the dealer.
Old Jan 26, 2009 | 09:02 PM
OSO's Avatar
OSO
Agreed ,and redo your wiring correctly before your filling an insurance claim.
Old Jan 29, 2009 | 03:13 PM
justinsanders
an insureance claim? for what??
