need help wit bolt sizes anyone
Old Jan 22, 2009 | 04:56 PM
sppneon's Avatar
sppneon
Default need help wit bolt sizes anyone
i havin trouble wit a couple of things.. but i really want to no wat size is the bolts for the tranny bracket.. the other things r the mounts wats size r those bolts.. the motor is out i just need to take theses things off and for some odd reason the 9/16 standard amd metric dont feet. some please help..
Old Jan 22, 2009 | 05:09 PM
iwalton63's Avatar
iwalton63
If i understand which ones you are talking about. Im pretty sure they are either 15mm or 18mm, i want to say there is both down but try those two.
Old Jan 22, 2009 | 05:12 PM
sppneon's Avatar
sppneon
thanks i no its not a 18 tho
Old Jan 22, 2009 | 05:39 PM
spudsterier's Avatar
spudsterier
which mounts?
the bolts that hold the mount to the car? or the bolts that hold the mount to the motor? or the bolts that hold the mount bracket to the motor?
is the car an auto or manual?
just about every bolt on a neon is metric...
Old Jan 22, 2009 | 06:25 PM
sppneon's Avatar
sppneon
its manuel. the mount that hold it to the car
Old Jan 22, 2009 | 11:15 PM
das2123's Avatar
das2123
Try a 6 point and 8 point socket of various sizes.
Old Jan 23, 2009 | 10:46 AM
spudsterier
the mount that holds what to the car? the motor or tranny?
passenger side mount:
2-15mm bolts holt the mount to the car
3-15mm bolts hold the mount plate to the motor
1-long 3/4" bolt holds the mount plate to the mount
front motor mount:
3-18mm bolts and 2-15mm bolts hold the bracket to the motor
2-15mm bolts hold the mount to the car
1-long 15mm bolt holds the bracket to the mount
tranny mount:
3-15mm bolts hold the mount to the motor
1-long 3/4" bolt holds themount to the car
5-speed trannys usually have a plate underneath that support the tranny to the block
2-18mm bolts hold the brace to the tranny
2-15mm bolts hold the brace to the oil pan
automatic trannys usually have a bracket on the back of the motor to support the tranny to the block
1-15mm bolt on the back of the tranny
1-15mm bolt on the back of the block
hope this is what you are looking for
Old Jan 23, 2009 | 11:33 PM
sppneon's Avatar
sppneon
whoa thanks man for all that this is exactly wat i need.. now maybe i can finish wit the car felt like givin up for a min thanks u guys
