speedodemeter and fuel gauge
Old Jan 25, 2009 | 12:12 PM
toshiba's Avatar
toshiba
Default speedodemeter and fuel gauge
Hey i changed my battery on my 1998 neon, now when i go to start the car my speedometer and fuel gauge are not working!!!! I checked the fuse everything is fine. I need know asap wat can be the issue. Thanks
Old Jan 25, 2009 | 01:06 PM
Nates_expresso's Avatar
Nates_expresso
does it still start and run?
If so, slap your dash with about the same force u'd use to slap your girl, and see if it comes back on.
If so, you get to resoder your instrimunt panal.
https://dodgeforum.com/forum/1st-gen...e-cluster.html
~Nate
Old Jan 25, 2009 | 02:10 PM
ajpranger's Avatar
ajpranger
~Nate
hey don't let your girl here that she might file charges against you. lol
Old Jan 25, 2009 | 02:39 PM
toshiba's Avatar
toshiba
can you gave a picture what area to solder
Old Jan 25, 2009 | 07:22 PM
Nates_expresso
What if she likes a little discipline sometimes?
https://dodgeforum.com/forum/1st-gen...er-repair.html
Old Jan 27, 2009 | 10:56 AM
toshiba's Avatar
toshiba
I did the solder Still is not working wat can i do?
Old Jan 27, 2009 | 02:03 PM
das2123's Avatar
das2123
You may not have done it correctly. Make sure the point changes color. You may have to add some solder.
Old Jan 27, 2009 | 02:33 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Yes. when I did my wifes car i had to add solder to the pins. If you have a stedy hand you can add flux for a flawless connection with a fine tiped hobby paint brush, then add silver solder. Use a decent soldering iron also. none of the cool to the touch tip soldering irons, to me, do not seem reliable.
Old Jan 27, 2009 | 03:08 PM
Nates_expresso
Try adding solder first, if not, you might have overheated something. A new cluster is like $30 at a yard. Are your other gauges working?
~Nate
Old Jan 27, 2009 | 06:04 PM
toshiba's Avatar
toshiba
my temputure gauge and the kilometer counter are working only. I might get a new cluster will tha fix my promblem?
