Dohc swap pics
Old Jan 27, 2009 | 01:18 PM
iwalton63's Avatar
iwalton63
Originally Posted by Ghost Neon 2
So, did you do any headwork or valve jobs before the install? What is you setup currently, and what is your issue to date?
The motor itself is stock, no real performance parts. But I did tear it down to the block and cleaned and replaced everything i could. as for the valve job, yes but i didnt replace the valves, just cleaned them up.
Heres a list off the top of my head of stuff that has been done to the car.
Dohc engine swap with 75K
MLS head gasket(modern performance)
Felpro head bolts
cam seals(napa)
Litens idler pulley
Litens mechanical tensioner
Gates timing belt
Napa water pump
Oem clutch/ TO bearing
Pacesetter header
Mopar performance pcm
Booger Bushings
52mm Throttle body
intake manifold gasket(modern kit)
exhaust manifold gasket(modern kit)
New Pcv valve
Thermostat
Champion spark plugs
Alt belt/ Ps belt
AC is taken out
New fuel pump
Dohc lettered valve cover
CAI
5% tint
Skunk 2 springs
Kyb gr2 struts
Monroe strut mounts
Depo headlights
Msr 17" wheels (powder coated)
Neongoodies Offset Tension rods
Tinted Euro tail lights
Tinted 3rd brake light
Alpine deck
2 12" Alpine type E's
2 6" Alpine type S's
2 Sony Mtx 6x9s
Dohc muffler
Custom short shifter
Custom 8 ball fuel valve
pretty much all parts got cleaned and painted before installing again too.
I know there is some more stuff but i cant think of anything else right now.
I wasn't planning on racing this car, I didn't need anything to crazy. I just need a semi quick daily driver. and that's what I got. My Sohc sucked up quit a bit of water a while ago and hydro locked that was the whole reason for swapping the engine. I did all the work by my self, it was the first time i have swapped/rebuilt a motor. so it was meant as a learning experience. I definitely did learn a lot. I am have full time job and also a full time student (I'm 18). So it did take a while to do, but i got it done.
Old Jan 27, 2009 | 02:08 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Sounds good. Good work. On my second engine the piston rings were the only thing left alone. Caused blow by and failure. Building a 2.4L this time. I'd recommend a ebay udp to really accent the mods you have. Keep up the good work.
Old Jan 27, 2009 | 02:15 PM
iwalton63's Avatar
iwalton63
yeah i know i was very close to getting MPx but the money got real tight at the end. so i had to put the stock one back on. maybe in the future hear ill get one.
Old Jan 27, 2009 | 11:11 PM
Ghost Neon 2
The ebay Megan udp is about $30-$40. Works the same.
Old Jan 28, 2009 | 11:07 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
nice eight ball... haha, looks good
Old Jan 28, 2009 | 12:10 PM
iwalton63's Avatar
iwalton63
haha thanks man
Old Feb 15, 2009 | 07:50 PM
cum4acummins's Avatar
cum4acummins
Must be a fellow 95er. I love them 95s.
