What fits,rubber for neon?
Old Feb 2, 2009 | 07:13 PM
moparborn's Avatar
moparborn
Default What fits,rubber for neon?
How big a tire/wheel will fit on a 99 neon sport?
Thanks for the input.
Old Feb 2, 2009 | 08:48 PM
sabin420's Avatar
sabin420
i have 205/40/17 and that's about the limit on a 7.5" wide rim. You will have to get wheel spacers for the rear to get a proper alignment, but I've found that's about the limit. Maybe a 40/18 or 35/18 can fit. But 205 is about the limit...start rubbing on the frame whille u turn.
Old Feb 3, 2009 | 10:27 AM
spudsterier's Avatar
spudsterier
18's fit with a 215/35-18 tire
17's fit and the largest tire you can use is 215/40-17 but 205/40-17 is the best
Old Feb 3, 2009 | 04:35 PM
sabin420's Avatar
sabin420
don't forget wheel spacers for the rear or you may run into scrubbing problems w/ the suspension components
Old Feb 3, 2009 | 05:18 PM
spudsterier
never had that problem on mine while using the 215/35-18's or the 215/40-17's
get wheels with the right offset and there wont be any problems
Old Feb 3, 2009 | 06:14 PM
12 volt's Avatar
12 volt
Q: What size tire should I use if I am getting bigger rims?
A: 195/60-14, 205/60-14, 195/55-15, 205/50-15, 215/50-15, 205/45-16, 215/45-16, 205/40-17, 215/35-18 are some common tire sizes that will fit.
Old Feb 3, 2009 | 06:42 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Don't forget the max 40mm offset
Old Feb 5, 2009 | 12:16 PM
98/\/eo/\/'s Avatar
98/\/eo/\/
225/50/16 will fit in the front no problems unless you got the wheel cranked all the way
Old Feb 5, 2009 | 12:26 PM
spudsterier
not much of a use for a tire that wide on a neon
Old Feb 5, 2009 | 11:40 PM
berretta96's Avatar
berretta96
I had 215/35/18's on and they BARELY rubbed if I cranked the wheel ALL the way. Wheels were 18x7 +40mm offset. I DIDN'T have any spacers on the rear and I was able to set the alignment perfect!!!!!
205/35/18 ??? WTF??? Never ever ever seen a 205/35/18. I used to manage a Goodyear and I've seen A LOT of tires and haven't ever seen a 205/35/18
