srt-4 turbo question
Old 02-15-2009, 09:53 AM
sarguy01's Avatar
sarguy01
sarguy01 is offline
boost on the srt-4 is controlled by the pcm via a solenoid that controls the boost.
you won't kill the turbo by running it with no coolant but like stated above you need to let it cool for a few minutes after EVERY time you drive. get a turbo timer and it does it for you.
Old 02-15-2009, 09:50 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
Originally Posted by I_Ride_Neon
Spud You need to help me confirm its 14? I have been looking and come to find out a stock srt-4 wastgate will only run 4psi if hooked straight vac. I have read it about 7 places. So I am lost. I wont buy the agp if I can get 4psi off the wastegate. I can use a boost controller to turn it up. Have you ever tried one? Everything I read was from forums.
now that you mention it, when i hooked the stock wastegate up, it did only run about 4psi....i figured that sumthing was just wrong with the wastegate
Old 02-15-2009, 10:13 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
Thanks! Thats what I was looking for!
Old 02-16-2009, 01:57 AM
chenzo's Avatar
chenzo
chenzo is offline
Just outta curiosity, why do you want to run so little boost?
Old 02-16-2009, 02:24 AM
I_Ride_Neon
2 reasons. I want to run low boost as a DD, and be able to turn it up when racing. The other reason is, I am building a srt-4 2.4 and will need to be broke in.
Old 02-16-2009, 02:31 AM
chenzo's Avatar
chenzo
chenzo is offline
Ah alright Makes sense then.
Quick Reply: srt-4 turbo question
