I finally got a response back from the dealer - he says that most of the race teams running Neons are using Red Line MTS in there cars
I have not tried Red Line - but I guess it is something I can try this weekend.
Greg
Greg
Quote:
ORIGINAL: NYG
Greg
redline MTF or MT-90 will work just fine in the neon trans. i actually have some mobile1 full synthetic in mine, with no problems so far, but may be changing it out soon for the Redline MTF. (reason is, im leaking at the axle seals, so, im gonna need to drain it, and i already have the redline mtf sitting there in the garage)ORIGINAL: NYG
Greg
If your neon call for ATF+4 do not use redline or what ever. Amsoil has an ATF+4 and that would be good. But they are now using a fibre clutching in the synchros that will not be lubed properly with gear oils. Friends neon trans died in about 10K miles with redline in his gearbox. Redline being the culprit. Snchros were fried. These were later models but just in case.
