OBD Code 12,1,1,1,1,55
Old Jun 1, 2009 | 02:52 PM
tripleduo's Avatar
tripleduo
Default OBD Code 12,1,1,1,1,55
Hello, My 97 neon SHOC 2.0 is reporting OBD Code 12,1,1,1,1,55. And I haven't got a clue as to what this type of report could mean because its not listed on the code list. She's randomly cutting off. Last night I was about 8 miles away from home she cut off on me for the first time. 5 mins later I cranked her up she started every thing was fine, then as I was driving home, she began to choke along, at one point I would give acceleration there would be no response, then acceleration would kick back in, then it would feel as if there was misfire somewhere. Engine light illuminated no surprise as I was expecting that. She done this for 8 miles to get me home, at times almost completely dying but hung on.
I love my car she has been good to me for 5 years. I don't want to part with her at 92,000 miles... Its way too early.
Could someone please help us as to shed a little light on what our problem could be. We would really appretiate the needed help. Thanks in advance.
Old Jun 1, 2009 | 06:11 PM
ldiablo233's Avatar
ldiablo233
The 1's have to be something else, like 31,22,13....
Old Jun 1, 2009 | 10:50 PM
9R/T.4door8's Avatar
9R/T.4door8
wats code 4? ne one know off the top of your head? i know 12 is battery dissconnect and 55 is the end code. check for bad battery or corroded battery terminals......maybe bad or dirty ground.....
Old Jun 2, 2009 | 03:20 AM
tripleduo's Avatar
tripleduo
Thats how the 1's came: 1 pause 1 pause 1 pause 1, then 55 end of report. I got word that it was leaking engine oil earlier that day cause my GF says it left a good brown spot in the driveway.
Thanks for the replys.
My Condition Report : Getting depressed...
Old Jun 2, 2009 | 03:32 AM
tripleduo's Avatar
tripleduo
Ya know 9R/T.4door8, you may have something, because when I took the battery off to have it tested a couple days ago I should've cleaned them before I reconnected it.
I will clean then crank her up and see how she runs... And post back... please wish me luck...
Thanks again everybody
Old Jun 2, 2009 | 04:12 AM
tripleduo's Avatar
tripleduo
Okaaaay... Cleaned the Battery terminals took her around the block thrice and... she runs great at the moment thank ya! It was just the battery terminals that needed cleaning WOW
Dropped the engine oil cap down the sewer OUCH!!! Anyone happen to know how and where I can obtain another? Will it hurt to drive without one for a while?
BUT... I'm still concerned about that oil slick. She's still dripping
My condition report: Greatful for the help, quite a bit happier , but that oil slick...
Old Jun 2, 2009 | 09:37 AM
das2123's Avatar
das2123
Oil leaks can be a lot of things. Could be oil pan gasket, rear main seal, camshaft position sensor, oil filter. Get down there and have a look.
Old Jun 2, 2009 | 10:39 AM
ldiablo233's Avatar
ldiablo233
Honestly you may be able to drive without it, but its too much to chance since the oil could spit out of it. Auto stores should have it and jy's too.
Old Jun 2, 2009 | 10:41 AM
das2123's Avatar
das2123
Driving without the oil cap off is a bad idea. Think of all the dirt and other crap that can enter your engine!!!
Old Jun 4, 2009 | 07:23 AM
1st Gen's Avatar
1st Gen
I put a quart of oil in my Mazda before heading out on a road trips one time. I drove a couple hundred miles before checking the oil and realized I left the cap off. It made a pretty bad mess of the engine compartment. I recommend stuffing a rag in there at the very least. Of course make sure the rag doesn't interfere with the workings of the rocker arms or any of that business.
