Engine loading up on fuel...
Old Mar 15, 2005 | 09:03 PM
99reddohc's Avatar
99reddohc
Default Engine loading up on fuel...
Ok after all the crap of getting my DOHC back together and running it seems as if its loading up on fuel. It pops out the exhaust and smells of pure gas. What could be causing this? I started it back up now it only runs with the throttle opened and wont idle on its own. And its still running lall funky (popping, starts hard shaking the car, and sputters a bit)
Old Mar 16, 2005 | 02:29 AM
casper's Avatar
casper
Default RE: Engine loading up on fuel...
I sounds like a PCM or sensor problem. Was is a SOHC to a DOHC swap? I would check all the wires and throw some fuel injector cleaner in.
