Cigarette Lighter
Old Mar 17, 2005 | 04:56 PM
tbl905's Avatar
tbl905
Default Cigarette Lighter
My 96 Neon has a cigarette lighter that doesn't work. Where can I get a non-expensive replacement part? I searched ebay but didn't find much except just the plugs. I need the holding piece as well.
Old Mar 17, 2005 | 04:59 PM
casper's Avatar
casper
Default RE: Cigarette Lighter
there is somethin called help, its a brand that is sold in most auto parts stores. it has odd parts, try that. I am sure autozone or somethin like that will have it cheap.
Old Mar 17, 2005 | 05:48 PM
RayDog26's Avatar
RayDog26
nope don't waste ur time going to parts stores... i had this problem when i bought my car. go to the dealer and tell them u need the shell for the cigarette lighter.. they will have to order it because i doubt they will have it in stock but it should only cost like $8.. thats what makes it throw the fuse.
Old Mar 19, 2005 | 07:59 AM
casper's Avatar
casper
I usually hate telling people to goto the dealer cause they are so expensive, but $8 isn't too bad.
Old Mar 19, 2005 | 01:47 PM
RayDog26's Avatar
RayDog26
yeh the dealer is the last place i want to go for parts but certain things only come factory and ur stuck going there...... this is a good example...atleast its cheap.
Old Mar 19, 2005 | 04:15 PM
casper's Avatar
casper
Ciagarette lighters are all the same, should just be a matter of getting one the right size for the hole in the dash and wiring it. Allthough $8 from the dealer is the way I would go.
Old Mar 19, 2005 | 04:35 PM
RayDog26's Avatar
RayDog26
yeh thats what i thought..... but like i found out with my speakers.... dodge puts special adapters on EVERY THING..... usually u can just buy a new shell in the help section but because on a neon it has that adapter you can only get it from a dealer.
Old Mar 21, 2005 | 12:43 AM
casper's Avatar
casper
I would just get it from the dealer.
Old Apr 13, 2005 | 05:50 PM
Tills's Avatar
Tills
Put your hand under the ciggerete lighter. There is a whole in the panel. If you feel around and check the power connection to the lighter may be disconected. That happened to me and i went under and reconnected it and the problem was fixed.
Old Nov 25, 2005 | 05:05 AM
neonfreak1988's Avatar
neonfreak1988
im going to be a smartass and say go buy a 50 cent lighter from the grocery store. lol
