Throttle Body changing
Old Mar 18, 2005 | 06:26 PM
95slammed4doorneon's Avatar
95slammed4doorneon
Default Throttle Body changing
has anyone put a auto DOHC Throttle Body on a SOHC 5 speed motor if so did it do anything
Old Mar 18, 2005 | 06:36 PM
AirWolf's Avatar
AirWolf
Default RE: Throttle Body changing
sweet lookin 1st gen love the colors would really like to see pictures of it slammed and Im not so sure that would work any thing auto in a 5 speed and vise virsa to a auto.
Old Mar 18, 2005 | 06:50 PM
95slammed4doorneon
more pics
[IMG]local://upfiles/13627/470C1170BA524F8584E4414F0A2E192E.jpg[/IMG]
[IMG]local://upfiles/13627/AA9C751712584950BA807EC8F7342B0C.jpg[/IMG]
[IMG]local://upfiles/13627/68C92F3C42B841AAB8B8505AC7AF007C.jpg[/IMG]
Old Mar 18, 2005 | 11:35 PM
99reddohc's Avatar
99reddohc
I have an Automatic throttle body on my 5sp....It does work very well it gives me better throttle response. The manual throttle body is 49mm as to the auto being 52mm in size. I have no problems with it.
Old Mar 19, 2005 | 01:33 AM
RayDog26's Avatar
RayDog26
wouldn't it be better to put a 60mm one on instead ??
Old Mar 19, 2005 | 07:41 AM
casper's Avatar
casper
The 52mm from the auto is fine for mild mods on a MTX. If you go turbo or build the motor, there are 55mm and 60mm abailable.
Old Mar 21, 2005 | 05:58 AM
RadarLove's Avatar
RadarLove
The TB's from atx DOHC's and SOHC's are the same, although the TPS is different. Just a matter of swapping sensors as needed.
Decent upgrade. I will be putting the mtx TB spring and cam onto the atx TB because it's just too jumpy. I don't mind so much on the street, but jerking/bouncing around cones at 50 mph in 2nd gear bites... Like mentioned, more than 52mm without forced induction is really a waste. 52mm flows plenty to support even a nicely built 170+ whp n/a car.
Best of luck!
Old Mar 22, 2005 | 03:20 AM
casper's Avatar
casper
Why would you switch the cam and spring, they should be the same.
Old Mar 22, 2005 | 08:26 PM
builtfourspeed's Avatar
builtfourspeed
I have a friend who builds DSM's and tells me that the throttle body from a Cherokee can be bolted on with no fab and is 55mm. I'll get the details and post back.
-Cheers
Old Mar 22, 2005 | 10:04 PM
95slammed4doorneon
that would be sweet man all i would need to know is the year and type
