want to buy a turbo!!!
Old Jul 9, 2009 | 01:45 AM
Relentless2.0's Avatar
Relentless2.0
Default want to buy a turbo!!!
Hi, I have a 97 plymouth neon 2.0l SOHC an i want to turbo it. what i want to know is, is anyone selling one for cheap??? I live in Corpus Christi Texas. Thanks!!
Old Jul 9, 2009 | 12:33 PM
das2123's Avatar
das2123
Do you know what all goes with adding a turbo to a neon?
Old Jul 9, 2009 | 07:17 PM
Relentless2.0
turbo, intercooler, pipeing, bov,wastegate, manifold, ect. oh an i dont plan on useing too much boost for now since i dont really have to much funds to upgrade to bigger injectors an better fuel pump. But thats just for now till i make a lil more money. I read somewhere that your stock internals will still hold if your running low boost... hope its true... im sure im missing stuff but any info would gladly be appreciated
Old Jul 9, 2009 | 07:53 PM
justskatenate's Avatar
justskatenate
true but if you wanna run it safely you might wanna invest in a new fel pro head gasket, arp head studs. either way you need to get probably at least better fuel injectors. stock internals should be fine for anything under proably 10...your gonna need an oil catch can, fuel pressure regulator and at least a wideband o2...there is a lot more than what is glorified in magazines
Old Jul 9, 2009 | 10:11 PM
Relentless2.0
well i just recently changed the head gasket like a month ago(fel pro). But thanks for the info an if you know anyone selling anything just let me know so we can try an work something out. Thanks
Old Jul 9, 2009 | 11:28 PM
das2123's Avatar
das2123
You are also gonna have to get a better fuel pump.
Old Jul 10, 2009 | 12:18 PM
justskatenate
ya you will. just get a walbro 255 lph. they are aroun 100 bucks but getting a new fuel pump is not an option...gotta do it. good luck man
Old Jul 18, 2009 | 12:06 PM
berretta96's Avatar
berretta96
nonsense.
another inexpensive option would be finding a used SRT 4 fuel pump from someone that upgraded. They don't flow as much as the walbro but they are a big jump from the 1st gens.
I just posted an srt turbofold forsale, you'd need to get a mattdog adaptor to use it though. Still definately the cheapest reliable option out there IMO
